Re: farmall c carb
Posted by jim from az on September 29, 2010 at 09:51:43 from (63.229.125.135):
In Reply to: Re: farmall c carb posted by gene bender on September 21, 2010 at 16:15:22:
hi gene i set this adjustment with drill bits for the gauge on the brass part that is soldered to float next to needle.., after about 6 times,, i got it to where it will run with choke out but it still leaks from carb any adjustment more and it leaks and floods out and any less and no fuel it was a new needle and seat, everything is clean, the floats are not filled with gas, the needle and seat works up and down when it's apart, what am i doing wrong , i could take this off in my sleep thanks jim
