Re: farmall c carb
Posted by rustyfarmall on September 29, 2010 at 11:08:09 from (209.152.78.140):
In Reply to: farmall c carb posted by jim from az on September 29, 2010 at 09:51:43:
Do the measuring with a ruler that is marked off in 1/64" graduations, and measure from the carb body to the highest point on the float. Also, you might want to take the needle out of the seat and clean it as there may be a tiny speck of rust that is preventing the flow of fuel from being completely stopped. Also, make sure the float is not rubbing on the sides of the fuel bowl, and when measuring and adjusting float height, make sure that BOTH of the floats are at the same exact height.
