Re: Adding lights to Farmall A w/ magneto
Posted by rustyfarmall on September 29, 2010 at 12:25:53 from (209.152.78.140):
In Reply to: Adding lights to Farmall A w/ magneto posted by Swedish Fish on September 29, 2010 at 11:50:57:
If you use the correct, #1133 bulbs, there is no difference in brightness between 6 volt and 12 volt. If you want really bright lights, you will need to go with the 12 volt conversion and some kind of aftermarket lights that will NOT look anything like the originals.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
