Re: Second day of cranking the A
Posted by Mayor on September 30, 2010 at 18:06:01 from (76.26.85.135):
In Reply to: Second day of cranking the A posted by Enar on September 30, 2010 at 13:40:57:
Depending on how long the tractor has been sitting....the valves will gunk up and even rust....which means that compression is low.....which means that starting without pulling the ole girl will be very hard too do.
I'd hook it up too a truck or another tractor and pull it and start it.....that turns the engine over alot faster and they usually pop right off.......once running, then adjust the carb settings and I'll bet you'll be pretty happy.
Be carefull hand cranking when putting fuel in the cylinders.....a small backfire could cause broken body parts!!!!.
