Re: Second day of cranking the A
Posted by oldtanker on September 30, 2010 at 20:27:46 from (66.228.255.223):
In Reply to: Second day of cranking the A posted by Enar on September 30, 2010 at 13:40:57:
If you can make it fire by putting gas into the throat of the carb then you have a fuel issue. I'd guess a plugged passage in the carb. You may need to take it apart and blow compressed air or carb cleaner through every little hole you can find.
Rick
