Re: Farmall H Valve Train
Posted by rustyfarmall on October 02, 2010 at 08:11:10 from (209.152.78.140):
In Reply to: Farmall H Valve Train posted by Jeff Ferguson4 on October 02, 2010 at 08:05:44:
The valves are stuck in the guides. Spray penetrating oil on the stems, and then lightly tap on the top of the valve stem with a smaller hammer. Give each stem a few taps, and then walk away for awhile. Maybe an hour or so later, do it all over again. Eventually, those valves will loosen up and be O.K.
You will need to remove the rocker arm assembly to gain full access to the valves.
