Whiring sound
Posted by farmall706 on October 02, 2010 at 21:50:13 from (71.244.240.126):
I have a 706 gas, there is a whiring sound under the platform behind the clutch. I take it this is the Hydraulic pump? Is it normal for the sound? Also when I disengage the clutch to start the engine and then let the clutch out it changes the RPM a small amount? Is that normal?
Thanks
