Re: Whiring sound
Posted by Zachary Hoyt on October 03, 2010 at 08:49:07 from (184.8.255.250):
In Reply to: Whiring sound posted by farmall706 on October 02, 2010 at 21:50:13:
The RPM change is normal because once you let up on the clutch pedal the disc, pressure plate, input shaft etc are turning which puts a slight load on the engine.
Zach
