Posted by amnion on October 03, 2010 at 18:51:29 from (66.44.149.71):
Neighbor's 560 engine likes to stall really easy. I noticed this earlier in the spring when I was drilling his barley for him and again tonight while seeing him pull wagons out of his field. The tractor won't move anywhere in any gear above 1st without at least half throttle. It will die abruptly every time, even when slowly releasing the clutch on level ground.
I have an H tractor that runs quite a bit differently. If the load is too much for the amount of throttle/gear combination on the H, the engine will noticeably slow, or "bog", down gradually before it kills. Popping the clutch in 5th is an exception of course.
Any ideas for what to adjust on the 560 to get it running a little more friendly?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
