Re: 560 gas likes to stall abruptly
Posted by CNKS on October 03, 2010 at 19:02:26 from (216.144.104.128):
In Reply to: 560 gas likes to stall abruptly posted by amnion on October 03, 2010 at 18:51:29:
Main jet adjustment for max power is with the jet needle 5 turns out. I call that jet a "fixed jet" that you can reduce the flow with the needle. It is not adjusted like your H. The carbs changed when the Super H/M appeared. Try that. Otherwise it is a fuel flow problem, anywhere from the tank to the carb needing an overhaul.
