Posted by Longbow on October 12, 2010 at 07:22:28 from (71.29.157.102):
Of all things to go wrong on my super C all the teeth were stripped from my oiler gear. Its on the shaft with all the speed gears. I"ve read everything in my shop manual and its not making a lot of since to me. I do know that I have to break it in half at the gear housing. I haven"t found anything that is clear on how to disconnect the drive shaft there and I don"t want to guess and make a mess of it. Also its not clear on how to get the gear out. Once place I read said that I have to remove the top (sliding) gears through the top of the housing and then remove the lower speed gears, which means loosening the differential and removing the rivet at the back of the top shaft. I thought that I had read that the gear could shaft could be slid out the front of the housing and and the gears taken off that way. I"m in the middle of planting my food plots and have to get this done right away. Is there anyone out there that can help me with some much needed advice?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
