Is this the LP tractor you first got 6-9 months ago?
I've got something you might could help me with. Got a Super M LP that has Char-lynn pwr steering unit. When I got it the hydraulic lines were a nightmare ( I should have saved a picture of it). I redid them and added a two spool open center loader valve.
There is a valve or splitter that goes between the pump and the loader valve. I don't know the technical name for it but it builds pressure for the power steering and acts as a flow divider. I think it just uses some kind of check valve to build the pressure. Problem is that it seems to be building a fair amount of heat in the hydraulic fluid. This thing was on the tractor when I got it.
Is there a better way to make the steering work and keep the open center loader valve or do I just need to go to a separate pump for the power steering?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
