Re: Homemade hydro-static steering for W-400
Posted by Wardner on October 13, 2010 at 22:01:36 from (4.154.239.213):
In Reply to: Re: Homemade hydro-static steering for W-400 posted by CenTex Farmall on October 13, 2010 at 21:16:23:
Centex,
I've actually had the tractor for about ten years. Yes, it is LP.
That valve is called a priority valve. I have several tractors that use them. I haven't noticed a heating problem but I am not a farmer and my run times are usually short.
A separate (or dedicated) pump is better as it narrows down a troubleshooting session. It also allows full hydraulic power to go to your loader.
