Super A bull gears
Posted by CNKS on October 15, 2010 at 17:17:07 from (216.144.104.128):
The actual gear is offset to one side from the center that it is riveted to, on the other side the gear is about even with the center. Diagrams are not too clear, but I assume the offset side goes to the inside, the flat side toward the wheel? This allows the gear teeth to more or less fit into the taper at the end of the axle splines.
