Farmall H Carburetor Kit Question
Posted by 68rs327 on October 16, 2010 at 13:46:48 from (64.130.144.166):
I am wanting to buy a Complete Carb Kit for My Farmall H. The only numbers I can find on the Carb are 6212DB. The Carb Kits I find say they are for 45108DB and 50981DA Carbs? My Farmall H is a 1947 and it has a IH Carb on it. Can you guys tell me which kit I need or are all the ones for the Farmall H the same? Also, where is the best and Cheapest place to buy the complete kit? Thanks
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
