Re: H Generator Change Out
Posted by glennster on October 19, 2010 at 14:11:31 from (76.223.246.189):
In Reply to: H Generator Change Out posted by Doug Kieta on October 19, 2010 at 13:36:07:
there are adjustable pulleys for the generators. the pulley will screw in and out to adjust the belt tension, like the water pump pulley on the h or m. here is one i found on ebay that has the adjustable pulley
