H Generator Change Out
Posted by Doug Kieta on October 19, 2010 at 13:36:07 from (67.142.130.32):
I finally have located a generator for my 51H and have two questions that need answered in order to complete the change out.
1. The pulley on the new genny is larger than the one on the automotive genny that was on the tractor when I got it. Thus, the belt won't fit. What is the correct size for the genny belt?
2. The top bracket does not have enough adjustment to allow for proper tensioning of the belt. In the full out position, the bracket bolts are 6" apart. I can only rotate the genny about a 1/2" - 3/4" towards the engine block. I'm wondering if the bracket is not the original. What length bracket should I have? How much adjustment do I need in case I have to have a bracket made to fit?
Once again, thanks for the help.
