Re: H Generator Change Out
Posted by gene bender on October 19, 2010 at 17:35:56 from (67.55.227.196):
In Reply to: H Generator Change Out posted by Doug Kieta on October 19, 2010 at 13:36:07:
What generator are you going to use now and what regulator. Do you need the adjustable pulley thats used on the H. There should be a tag on the gen with a Delco Remy #.
