Re: IH 504 Dies after releasing starting switch
Posted by Jim on June 21, 2000 at 21:34:05 from (199.240.128.67):
In Reply to: IH 504 Dies after releasing starting switch posted by Rex on June 21, 2000 at 21:11:04:
The resistor is bad .When you hit the starter there is a wire from the starter(the R termenal) to the coil that bypasses the resistor. The coil has power to it only when the starter is engaged.
Post A Followup
: Re: Re: IH 504 Dies after releasing starting switch
