Ok so what did I do wrong???
Posted by old on October 22, 2010 at 16:31:15 from (4.245.3.94):
Every thing was going so good till I put the head on the BA. Tried to turn it over and I can get it to TDC on #2 and 3 or if I turn it back wards TDC on #1 and 4 but that is where I run into a problem from there it locks up. Now to fill in the gaps a bit. I used the block from the B that had the dome pistons but the head from the A that had the flat top pistons. But I do not remember if I tried to turn the engine over a full 360 before I set the head on or not so not sure if it is the problem with the head or maybe I put the rods in back wards but I do not think so since I looked at the numbers on the A engine and all the # where on the oil filter side. I think maybe the A head has been milled or something and I know that would cause this problem. Oh well guess I'll go out and pull the head back off
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
