Re: dead in the water
Posted by Janicholson on October 23, 2010 at 07:49:54 from (67.72.98.45):
In Reply to: dead in the water posted by Dave Cook on October 22, 2010 at 19:13:41:
Under the starter switch on the starter there is a copper terminal. This terminal becomes part of the switch contacts when the switch is mechanically moved with the starter rod. The terminal is not making contact with the switch. Use a chainsaw file or small rat tail file to oval the mounting hles on the switch so that it moves closer to the terminal (usually a half hole diameter is needed)
This allows current flow. Be sure to follow the real wiring diagram (from Bob M in the archives) to assure correct wiring, Jim
