Re: F 20 aquired
Posted by usetabesteve on October 25, 2010 at 07:08:36 from (168.166.54.11):
In Reply to: F 20 aquired posted by BillfromIL on October 24, 2010 at 21:52:48:
A 1938 F-20 could have been ordered with the hydraulic lift, and electric lights and starter. Those accessories could also have been added later. If the starter bolts to a cast bell housing it's probably factory.
Most dealers would install M&W and Behlen additions as well as IH manufactured and IH "approved" accessories. Your tractor may also have some "farmerized" accessories like that angle iron light bar.
The only good way to tell IH pieces from other pieces is to look for a casting number or decal. IH had all their stuff labeled one way or another. They also used things like generators and starters that were made by Delco. I don't believe any of the tractor manufacturers made magnetos.
