Re: M Spark ?
Posted by Allan In NE on October 28, 2010 at 14:13:57 from (148.66.88.254):
In Reply to: M Spark ? posted by MIKEINLC on October 28, 2010 at 13:58:33:
Are you talking about the primary or the secondary has no power out?
Which coil wire is new, primary or secondary?
Is the distributor shaft turning?
Are you by chance testing the primary with a test light while the points are closed? If so, it's gonna show "no power".
Allan
