Re: M Spark ?
Posted by MIKEINLC on October 28, 2010 at 14:43:05 from (64.254.184.128):
In Reply to: Re: M Spark ? posted by Allan In NE on October 28, 2010 at 14:13:57:
Allan, I hooked a test light on the terminal of the coil that has the wire coming from the resistor and have power, this is the positive terminal on the coil. I hook the test light on the negative terminal of the coil, which has a wire that runs to the distributer. No light. Can you clarify for me what you mean by primary & secondary, I'm kind of tractor illiterate. Will double check but thought distributer was turning alright. Thanks didn't know about no power with points closed!!
