Re: Farmall MD Wiring Help
Posted by janicholson on October 29, 2010 at 13:52:11 from (199.17.6.10):
In Reply to: Farmall MD Wiring Help posted by Matt Weltz on October 29, 2010 at 12:00:09:
The other terminals on the light switch might have been for the 4th terminal on the VR (L terminal). It should probably be connected to the Amp meter load side. (if the light switch has 4 positions it might be a regulator control type light switch, but it would not have been original that way.
The alternator should put out 14.2 to 14.5 volts.
If it is when running at 3/4 speed, it is charging, and doing well. if it is at battery voltage, 12.6 or so it is not charging.
Bob M wiring diagrams are the real thing, look them up in the archives. Jim
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
