super h 1953 hydralics belly pump
Posted by thomas thorn on October 30, 2010 at 04:18:04 from (74.32.140.178):
hi i have a super h i just installed a freeman loader on my question is the ram feed lines they are hooked together with a tee on the left side where ther is two ports the h it came off from they had it hooked to the back port. can you tell me whtch port it should be hooked to and what is the diffrence in the ports from the left side 2 to the right side 1 the loader is hooked up to the left front now it works beter whats the diffrence ,should it have a hose hooked to each side thanks tom ih54
