Re: super h 1953 hydralics belly pump
Posted by dej(jed) on October 30, 2010 at 04:44:00 from (67.234.178.130):
In Reply to: super h 1953 hydralics belly pump posted by thomas thorn on October 30, 2010 at 04:18:04:
It will work with a a T hooked to either front out let. It would probably work better with 2 separate lines on each of the front ports. The rear port was for a time delayed lifting system. When you pull the rod, the last port on the left side will activate slightly slower than the front 2 do.
