Re: 1256 International tractor hydraulic lines
Posted by Ed Pap on October 31, 2010 at 19:31:22 from (74.42.203.78):
In Reply to: 1256 International tractor hydraulic lines posted by Jamesb91 on October 31, 2010 at 13:30:16:
Can you repair your old ones? I have brazed alot of cooler lines over the years. if you have a rotted section you can cut it out with a tubing cutter and put rubber hose in that section. you must use oil cooler hose (oil resistant) and side it on the tube about 4 inches and double clamp it. if you want to stay original a salvage yard should have them. good luck Ed
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
