Re: 1256 International tractor hydraulic lines
Posted by Ed Pap on October 31, 2010 at 19:46:08 from (74.42.203.78):
In Reply to: Re: 1256 International tractor hydraulic lines posted by Ed Pap on October 31, 2010 at 19:31:22:
I just thought of something you might be looking for the power steering lines. they run between the frame and the engine and go under the radiator to the steering gear.those lines are high pressure (1500 psi) and have a special end. you can get those lines from CaseIH. they split in the middle inside the frame.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
