Re: Question about fast hitch adjustment
Posted by Jim Becker on November 02, 2010 at 06:53:27 from (173.74.120.16):
In Reply to: Question about fast hitch adjustment posted by Brendon-KS on November 02, 2010 at 03:44:43:
It is important to keep in mind that all Fast-Hitch operation is NOT the same. Just because an implement has 2 prongs on the front, doesn't mean it will work properly on any Fast-Hitch tractor. Among the 2-point tractors, The Super C, 200, 300 amd 400 Farmalls were the only ones with depth control (pitch) built into the front of the hitch. Most anything later had some type of draft control built into the hitch. Pitch adjustments were built into the implements. If there is any general rule, later implements with a pitch adjustment can be used on an earlier tractor but using an early (non-adjustable) implement on a later tractor doesn't work so well.
These comments ignore the possibility of hitches of one series that are mounted on tractors of another series. So don't bother "correcting" me with stories about a early style hitch on your 460 or whatever. I am also ignoring the hitch on the 300 Utility, which was a complete oddball. I'm just trying to explain to Brendon that some disks have a pitch adjustment and others don't. For his hitch, he should have one with the adjustment.
