Re: Super H Stopped Running and Will Not Start
Posted by r4etired on November 06, 2010 at 16:26:49 from (166.227.83.135):
In Reply to: Super H Stopped Running and Will Not Start posted by Angusman on November 06, 2010 at 15:26:04:
Coils are like light bulbs They fail quickly only sometimes after they cool down they will temporarily work. I would check for incoming voltage at the coil, you may have a bad switch or wiring.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
