Super H Stopped Running and Will Not Start
Posted by Angusman on November 06, 2010 at 15:26:04 from (99.195.117.219):
We were using the Super H last weekend for a hayride and all of the sudden it started sputtering and stalled out. Now it will not start at all. It is getting fuel to carb. When I pull a spark plug I do not see it firing. I looked at roto-bug which is only few weeks old and it looked ok. Is it possible the coil went out and if so would it just stop running like that. Is there a way to test coil? Any other suggestions would be appreciated.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
