Take the wires off your coil. Get a OHM meter. Your OHM's reading will be 366 OHM's then drop to 5 to 9 OHM's. If you get 36 OHM's then drops to 5 OHM's you have a bad coil. I just had a new coil go out and that was the readings I was getting on mine.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
