Re: Super H Stopped Running and Will Not Start
Posted by El Toro on November 07, 2010 at 03:04:40 from (108.3.200.96):
In Reply to: Super H Stopped Running and Will Not Start posted by Angusman on November 06, 2010 at 15:26:04:
Check to make sure you're getting battery voltage to your coil if you have a distributor. With the points open and your ignition switch in the on position you should have battery voltage on both small terminals on the coil. If there's no voltage here you need to check your ignition switch for voltage. Run a separate wire from your battery to the coil then see if the tractor will start. Hal
