Re: Farmall A - What do I need?
Posted by The perfect belly mower f on November 07, 2010 at 10:07:34 from (67.72.98.45):
In Reply to: Farmall A - What do I need? posted by KD Cannon on November 07, 2010 at 08:24:05:
The perfect belly mower for that tractor has an engine mounted on it (18HP or so). this allows it to have speed control, and cutting without being pushed around by the mowers inertia.
A pulley system to use the PTO is available, but might cost as much to install and connect, as an separate engine. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
