Re: Farmall A - What do I need?
Posted by CNKS on November 07, 2010 at 11:15:31 from (216.144.104.128):
In Reply to: Re: Farmall A - What do I need? posted by The perfect belly mower f on November 07, 2010 at 10:07:34:
Speed control is a good idea. 18hp? Depends on how it is rated, engine or PTO HP. I have a JD 525, riding mower, 48", 18 engine HP, very manueverable, prefer it by far to the belly mount Super A 60" Woods for lawn grass and other small grass and weeds. But, my Super A's 19 PTO HP gives far more power than the lawn mowers engine for taller weeds and grass. My belly mower does not get pushed around, nor does the 525. Your idea is fine for an addition to an existing riding mower though, you can double the cut.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
