Quick Question about wiring a Cub.....
Posted by RTR on November 07, 2010 at 18:05:03 from (74.248.177.53):
Ok, so I am using the wiring diagram found on the photobucket site everyone on here uses for the 12 volt conversion. By following it, it says to put a "Warning Light" in-line between the alternator (terminal #1), and the On/Off Switch.
Question is: when is the light supposed to come on, and how do I know it is wired up correctly so it will work the way it should.
The light I bought simply has 2 prongs, and the directions on the light package said one was for "Accessory" and the other was the "Ground". I simply hooked the light up in-line between the alternator and the on/off switch using the 2 prongs like the Farmall wiring diagram stated. Is this correct???
