You need an INCANDESCENT LAMP the newer LED's have too much resistance and dont allow enough curent flow to excite the alternator !!!!!!!!!!
It should turn on when you turn on the ignition and shes not started. Thats cuz the to ground side (other bat side gets voltage when key is turned to on) gets a ground via the alternator.
It should turn off running if the alt works cuz the voltage on both sides of lamp is same so no current flow means no light
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
