Re: 2606 voltage regulator oil pressure sender.
Posted by bc on November 08, 2010 at 15:48:52 from (71.158.222.35):
In Reply to: Re: 2606 voltage regulator oil pressure sender. posted by caterpillar guy on November 08, 2010 at 15:37:00:
Thanks. The fuel guage has never budged. I guess there should be some resistance somewhere. I assume the other wire is a hot wire but I'm not sure right now if it is hooked to something hot or not.
There is no oil sender anywhere. That's the problem. There are bolts where the oil filter housing attaches to the engine and about a 3/4" or so drain plug just where the filter screws on (thread end down) to the housing which would make a fitting stick out fairly far. I've been all over the engine looking for a fitting or plugged hole. This is a replacement engine.
