Re: 2606 voltage regulator oil pressure sender.
Posted by caterpillar guy on November 08, 2010 at 15:37:00 from (66.188.53.165):
In Reply to: 2606 voltage regulator oil pressure sender. posted by bc on November 08, 2010 at 13:02:22:
For the oil gauge you can put a Tee in where the oil sender is for the idiot light and run tubing from that. The lights should come on with the ignition off. For the fuel gauge just get a generic sender the one from the dealer will be a fortune. If you check it just move the arm in the tank up and down if the OHMS meter needle moves it should be good. There are 5 screws that hold it in the tank plus the hot wire on the center.
