706 aux hydraulics
Posted by MattSillinois on November 10, 2010 at 05:10:48 from (12.4.26.248):
I've got a gas 706. It has three hydraulic ports. One set on each side of steering wheel and one set behind the seat. I want to run a second set to behind the seat. Is the left or right side of steering wheel I need to plumb to rear of seat?
I know one set on the side of steering wheel and the rear one is the same so I am told but which is which.
Thanks in advance
Matt
