Re: 706 aux hydraulics
Posted by caterpillar guy on November 10, 2010 at 18:25:36 from (66.188.53.165):
In Reply to: 706 aux hydraulics posted by MattSillinois on November 10, 2010 at 05:10:48:
If you go to a junkyard you can get the lines to go to the back without all the nonsense and wont have to trip over the hoses running back. You will ned to get the longer hollow bolts that hold them on. The lines just stack ontop of each other. There are o-rings between the lines you will need.
