The wire that goes from the ignition switch to the solenoid and then on to the coil is not a standard copper wire.The part of the wire that goes between the key switch and solenoid is actually a resistor wire. It takes the place of an external ignition resistor. when the starter is engaged the solenoid switch also energizes that wire bypassing the resistance to furnish higher voltage to the coil for starting.
If the original wire is not reusable, and you do not find any resistance wire to replace it, you can use regular copper wire and an external ignition resistor to replace it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
