Posted by pete 23 on November 12, 2010 at 19:36:44 from (184.12.34.48):
In Reply to: Farmall 460 carburetor posted by Roger Reeves on November 12, 2010 at 19:06:24:
I would say you have intake manifold leaks as they do not align properly now with different exhaust manifold. You could spray something like w-d 40 or any penetrant where intake manifold fits to head and if engine changes speed or runs differently you have a leak. Most of the time on these old tractors you will need to surface the manifolds as a unit after they are bolted together. There is also a couple different gaskets used on these engines and a tightening procedure to be followed.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
