Re: Farmall 460 carburetor
Posted by Roger Reeves on December 11, 2010 at 17:12:24 from (66.116.21.37):
In Reply to: Re: Farmall 460 carburetor posted by pete 23 on November 12, 2010 at 19:36:44:
I tried spraying WD-40 around the manifold while the tractor was running ( choke out and high rpm). The WD-40 was sucked in. I took off both manifolds and sure enough, the new exhaust manifold was not in line with the original intake manifold. The exhaust manifold was at least a sixteenth of an inch proud of the intake manifold. I took both manifolds as a unit to a machine shop and had them planed so that they were perfectly aligned. Today, I put the manifolds back on the 460. With the choke out and the throttle nudged a bit past idle, the engine fired up after just a few revolutions and ran great! Thank you to those that responded to my problem on this forum: you saved the day!!!!
