Re: search function failing me super A suffix numbers
Posted by outlar on November 13, 2010 at 06:36:57 from (74.198.8.59):
In Reply to: search function failing me super A suffix numbers posted by old on November 09, 2010 at 06:53:45:
I'm relating some stats which relate to my 51 SA.
No offense to anyone, I am compiling some numbers I've read from some of Hugh's and many other members whom have discussed this topic at great length. For them I am thankful.
(raised) Casting Codes are in Month Day Year , year being letter code, X for 51 etc.
The 354 898 block is 1 7/16 (in.)" block bore, Or outside diameter of cylinder sleeves.
Head gaskets without factory waterpump have larger coolant passages on the head gasket. Only a general rule of thumb , not gospel or fact.
The engine serial number is above the distributor ,behind the throttle shaft ,on a flat , stamped , it will be covered in oil from the valve cover leakage.
