Re: Engine heater for an H Farmall
Posted by wayne in mn on November 13, 2010 at 10:18:55 from (66.228.242.147):
In Reply to: Engine heater for an H Farmall posted by matthies on November 13, 2010 at 09:45:24:
Have had a "head bolt heater" that replaced one of the head bolts in years past.
Have also more recently used "tank heater" style plumbed into the block drain for cold liquid source and a pipe installed below the thermostat for hot liquid returning to the block.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
