Engine heater for an H Farmall
Posted by matthies on November 13, 2010 at 09:45:24 from (209.222.185.90):
Has anyone put an engine heater on an H, thought of putting one from the block drain to the temp. sender with a pipe tee. That's if the drain plug is 1/4 pipe. thanks chris
