Posted by badaugherty on November 13, 2010 at 13:31:11 from (74.113.173.33):
What started out as a rusty fuel tank has turned into not being able to get the tractor running again.
In August I cleaned the tank and sealed it with Red Kote. Used the tractor to get in my rye and vetch and a couple of food plots. I was running poor, popping and I started monkeying with the carb and it just refused to run. I figured I had some rust of something in there and put a carb kit on it. That didn't work, so I started looking at the ignition and replaced the plugs, wires, coil, condenser, and points. I can get it to fire and it will run if I advance the timing, but now I have fuel pouring out the bottom of the carb if it doesn't fire and it's not a little bit either. It used to fire right up and idle along. I never had to the use the choke and now I'm choking it and running down the battery cranking on it. Speaking of, I ended up getting the starter rebuilt too. Anyway, those new Mahindra utility tractors are starting to look real good.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
