Re: search function failing me super A suffix numbers
Posted by outlar on November 13, 2010 at 18:05:55 from (74.198.8.57):
In Reply to: search function failing me super A suffix numbers posted by glennster on November 09, 2010 at 06:53:45:
Correction; The head cast number is 251172R1 not the previous listed number in the opening post.
A high flow head for the block may well be the 355 and 356 cast numbers.
